[GRASS-dev] Is the dash a Mapset naming restriction?
Tue Dec 10 02:16:27 PST 2013
Nikos Alexandris wrote:
> "g.mlist rast pat=hpf* mapset=pre-processing_post"
> gives a "Segmentation fault".  Is the dash an unwanted character in naming
> Mapsets?  I don't see a segfault with "normal" Mapset names.
A dash is supposed to be valid in names of maps, mapsets, locations,
etc.
This is one of the main reasons why r.mapcalc supports quoting of map
names.
FWIW, I can't reproduce the issue in 7.0 with a simple test case.
