[GRASS-dev] Major changes in the temporal framework
Luca Delucchi lucadeluge at gmail.com
Fri Dec 27 16:43:34 PST 2013
On 22 December 2013 00:07, Sören Gebbert <soerengebbert at googlemail.com> wrote:
> Dear all,
Hi Soeren,
> just for your information:
> I will commit several modification to the temporal framework (grass7
> trunk) in the next weeks, that will change the SQL database layout and
> the API. The goal is to make the temporal frameworks SQL database
> interaction much faster, reducing the number of tables to scale better
> with tens of thousand of maps, improving the PostgreSQL
> compatibility/performance and make it better maintainable.
these changes could be useful for create temporal dataset using maps
outside current mapset?
this change for my point of view is really important, if you break the
API could I suggest you add also this "feature" to temporal framework?
Thanks a lot
> Best regards
> Soeren
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
