[GRASS-dev] [GRASS GIS] #2148: wxGUI modeler: allow to name elements in the model schema
GRASS GIS trac at osgeo.org
Sat Dec 28 04:32:24 PST 2013
 Reporter:  mlennert           |       Owner:  grass-dev@…
     Type:  enhancement        |      Status:  new
 Priority:  normal             |   Milestone:  7.0.0
Component:  wxGUI              |     Version:  svn-trunk
 Keywords:  modeller comments  |    Platform:  Unspecified
      Cpu:  Unspecified        |
Comment(by mlennert):
 Replying to [comment:1 martinl]:
 > Replying to [ticket:2148 mlennert]:
 > > It would be nice if by changing the name of an object in the Objects
 tab, this name would replace the name of the command in the model display.
 Currently setting this name just is ignored and is lost after saving and
 reopening the model.
 > it was hopefully fixed in r58518, you can set action name/label in
 'Items' tab or from contextual menu ('Set label').
 Works now, thanks !
 > > In addition, the possibility to add comments would be nice, possibly
 in the form of a comment object that would be ignored in the model.
 > This has been implemented in r58521. You can set comments from
 contextual menu, it's saved to model file. I am not sure how to display
 them, probably as tooltips or directly in the object shape below label.
 Any opinions?
 I think the ideal would be to be able to add comments independent of
 objects. Sometimes comments can be about a process that includes several
 objects. And for such comments it would be nice to have a specific form
 not yet used by other types of obects (triangle, hexagon, ...).
 And to push things even further: it would be nice if these comments then
 also show up in the Python code...
 Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2148#comment:2>
