[GRASS-dev] formatting expressions for r.mapcalc in GRASS6.4.3
Sat Feb 2 05:27:37 PST 2013
Helena Mitasova wrote:
> Over the years there have been changes in the formatting of r.mapcalc expressions
> and it appears the currently there is no single way that would work everywhere
> (you either need quotes or it does not work with quotes and in GRASS6.4.3 the space around = is not necessary).
> I have tried to summarize our experience on MSWindows, Mac and linux here
> http://courses.ncsu.edu/mea582/common/GIS_anal_grass/mapcalcformats.html
> My question about the document above - is this how it should work?
>From the command line, the most portable approach is to use:
	r.mapcalc "outmap = whatever"
That should work in any version on any platform.
GRASS 6 simply concatenates all arguments with a space between each
one, and uses the result as the expression.
GRASS 7 uses G_parser():
	Usage:
	 r.mapcalc [expression=string] [file=name] [--overwrite] [--verbose]
	   [--quiet]
The above example is shorthand for:
	r.mapcalc expression="outmap = whatever"
For this to work, the expression must be a single argument (i.e.
quoted), and there must be a space between the output map and the
first "=". Using:
	r.mapcalc "outmap=whatever"
would result in G_parser() complaining that "outmap" isn't a
recognised option name.
