[GRASS-dev] GRASS GIS nightly builds
Rashad M mohammedrashadkm at gmail.com
Sat Feb 16 02:00:47 PST 2013
I am updating the version number it was like this:
package name: grass70
version 7.2
martinL pointed out the version problem and now  changing to this:
version 7.0
I need to make some more modification to make this work
with previous version i had daily updates but version mismatch is a serious
issue
sorry for the incovenience
On Sat, Feb 16, 2013 at 2:59 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Sun, Jan 13, 2013 at 2:37 PM, Rashad M <mohammedrashadkm at gmail.com>
> wrote:
> > I had tested the ppa packages on ubuntu precise and there seems to have
> some
> > issues
> > 1. grass startup script not working
> I have checked
> https://launchpadlibrarian.net/131311585/buildlog_ubuntu-precise-amd64.grass7_7.0-1~svn55042~ubuntu3_FAILEDTOBUILD.txt.gz
> and seen this:
> cp /build/buildd/grass7-7.0/debian/xgrass7
> /build/buildd/grass7-7.0/debian/grass7/usr/bin/grass70
> cp: cannot create regular file
> `/build/buildd/grass7-7.0/debian/grass7/usr/bin/grass70': No such file
> or directory
> make: *** [install] Error 1
> Perhaps just the name is a bit different? Above I see a line
> make[5]:
> `/build/buildd/grass7-7.0/dist.x86_64-pc-linux-gnu/docs/man/man1/grass7.1'
> is up to date.
> so the start script maybe "grass7.1" rather than grass70 (as it should
> ideally be).
> Markus
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130216/c639cccf/attachment.html>
