[GRASS-dev] Additional switch(es) for <g.mapsets>?
Martin Landa landa.martin at gmail.com
Sat Feb 16 05:50:25 PST 2013
2013/2/16 Nikos Alexandris <nik at nikosalexandris.net>:
GRASS 7?
> Would you consider adding an optional "-r" (as "remove") switch to the
> <g.mapsets> module?
there is already `operation=remove`.
> Or, add an optional switch "-s" or "-x" (as "select-ive/-ed" or as
> "exclusive") which will add the specified mapsets (parameter "mapset=") and
> remove the rest (but the current, of course)?
you can use `operation=set` to define search path from scratch. See the manual.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
