[GRASS-dev] Bash aliases in GRASS
Nikos Alexandris nik at nikosalexandris.net
Sun Feb 17 10:02:02 PST 2013
Nikos Alexandris wrote:
> > > #export GISBASE=/opt/grass-7.0.svn
> > > export GISBASE=/usr/local/src/grass/svn/dist.x86_64-unknown-linux-gnu
> > Shouldn't the following:
> > > tmp=/tmp/grass6-"`whoami`"-$GIS_LOCK
> > be rather: tmp=/tmp/grass7-"`whoami`"-$GIS_LOCK
Glynn Clements wrote:
> The name really doesn't matter. GRASS only ever accesses the file via
> the GISRC environment variable.
o-kay.
[@Hamish] I'll try to simplify the Wiki again.
> > > export GISRC="$tmp/gisrc"
> > > mkdir "$tmp"
> > and the following:
> > > cp ~/.grassrc6 "$GISRC"
> > be rather: cp ~/.grass7/rc "$GISRC"
> Again, it doesn't actually matter unless the same file is supposed to
> be used when creating a GRASS session via the startup script.
> FWIW, I do have a ~/.grass7/rc file; the timestamp is Feb 2010, which
> shows how often I run the startup script.
Thanks, Nikos
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130217/20a10dfc/attachment.pgp>
