[GRASS-dev] [GRASS GIS] #1887: improve signal to noise ratio in the build logs
GRASS GIS trac at osgeo.org
Sun Feb 17 21:05:22 PST 2013
 Reporter:  hamish       |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  6.4.4
Component:  Compiling    |     Version:  svn-trunk
 Keywords:  make         |    Platform:  Linux
      Cpu:  x86-64       |
 currently the build logs are highly cluttered with warning messages such
 as:
 Make/Grass.make:423: warning: overriding commands for target ...
 Make/Grass.make:414: warning: ignoring old commands for target ...
 Make/Script.make:47: warning: overriding commands for target `install'
 Make/Rules.make:99: warning: ignoring old commands for target `install'
 e.g. using the 6.4.3svn wxGUI g.extension.py to install an addon shell
 script creates this output in the GUI output window:
 Fetching <r3.in.xyz> from GRASS-Addons SVN (be patient)...
 Compiling...
 /home/hamish/dev/grass/svn/grass64svn/dist.i486-pc-linux-
 gnu/include/Make/Grass.make:423: warning: overriding
 commands for target `/home/hamish/grassdata/ll_wgs84/hb/.tmp
 /debSqx86-vm/29440.0/r3.in.xyz/bin'
 gnu/include/Make/Grass.make:414: warning: ignoring old
 gnu/include/Make/Script.make:47: warning: overriding
 gnu/include/Make/Rules.make:99: warning: ignoring old
 /bin/sh: cannot create
 gnu/locale/scriptstrings/r3.in.xyz_to_translate.c: Directory
 nonexistent
 sed: couldn't flush stdout: Broken pipe
 Installing...
 Updating metadata file...
 Installation of <r3.in.xyz> successfully finished
 but if you "grep -v 'warning: .* commands for target'" away the useless
 warnings that gets reduced to this:
 Compiling...
 nonexistent
 Installing...
 ... much more informative and you have a much better chance to spot any
 real errors which may have happened along the way.
  * what does it mean?
  * if it is benign, can we make it go away without masking any real
 problems?
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1887>
