[GRASS-dev] [GRASS GIS] #1606: WXGUI regression - attribute query tool reports "nothing found" when clicking on a vector object
GRASS GIS trac at osgeo.org
Mon Feb 18 00:06:43 PST 2013
  Reporter:  marisn       |       Owner:  grass-dev@…
      Type:  defect       |      Status:  reopened
  Priority:  blocker      |   Milestone:  6.4.3
 Component:  wxGUI        |     Version:  6.4.3 RCs
Resolution:               |    Keywords:  query
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment(by marisn):
 Just retested with 18 feb. 6.4.3 SVN build for Windows. Bug is still
 present.
 Here are exact steps to reproduce in Spearfish:
 v.net input=roads at PERMANENT points=archsites at PERMANENT
 output=roads_to_archsites operation=connect thresh=1000
 Use WXGUI to query attribute data of any of archsites in
 roads_to_archsites map. It is required as v.net.* modules need CATs for
 start/end nodes.
 Sorry about that d.vect reference, as I was falsely assuming that GUI is
 querying only on displayed level.
 PS. Helmut - You are right. There is no problem with v.what as it works as
 expected. The problem is in WXGUI.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1606#comment:8>
