[GRASS-dev] [GRASS GIS] #1554: wxGUI Cartographic Composer: preview broken on Windows
GRASS GIS trac at osgeo.org
Mon Feb 18 10:53:36 PST 2013
 Reporter:  martinl                                 |       Owner:  grass-dev@…
     Type:  defect                                  |      Status:  new
 Priority:  critical                                |   Milestone:  6.4.3
Component:  wxGUI                                   |     Version:  unspecified
 Keywords:  cartographic composer, psmap, wingrass  |    Platform:  MSWindows XP
      Cpu:  Unspecified                             |
Comment(by hamish):
 Replying to [comment:15 annakrat]:
 > There is a way to distinguish between active and nonactive tabs
 > it (text color) but I think it's not possible to highlight
 > individual tabs. What exactly you would like it for?
 I didn't mean to highlight the tab, but rather to give the green triangle
 run button a backlit yellow sun glow when the Preview tab was switched to
 -- trade out the icon, then trade it back once the rendering was done.
 Replying to [comment:17 wenzeslaus]:
 > Maybe there is one (for programmer) complicated and (for user)
 > unclear way to deal with generation. Start a timer after switching
 > a tab and after a while if the tab is still active start with
 > generation.
 If the computation were relatively cheap that could be ok, but since it
 can be expensive I'd vote to stick with the user-initiated approach. (just
 make it more obvious)
 Along the line to make it more obvious: how about if the initial preview
 document loaded a dummy graphic which had a picture of the green triangle
 button circled and an arrow pointing NW saying "click up there to generate
 preview".
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1554#comment:18>
