[GRASS-dev] Additional switch(es) for <g.mapsets>?
Markus Metz markus.metz.giswork at gmail.com
Tue Feb 19 04:07:56 PST 2013
On Tue, Feb 19, 2013 at 11:25 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Mon, Feb 18, 2013 at 11:03 PM, Markus Metz
> <markus.metz.giswork at gmail.com> wrote:
>> On Mon, Feb 18, 2013 at 10:39 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>>> On 18 February 2013 20:08, Markus Metz <markus.metz.giswork at gmail.com> wrote:
>>>> On Mon, Feb 18, 2013 at 6:51 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>>>> Since the -s flag does not add new functionality to g.mapsets, I would
>>>> strongly opt to remove the -s flag.
>>>> If you want to use the customized gui interface for
>>>> r.in.gdal/v.in.ogr/r.colors/v.clean/i.group/g.mapsets etc, use the gui
>>>> menu.
>>>> Otherwise, you can use the command line.
> This makes perfect sense: i.e. g.mapsets fired up from cmd line
> without anything pops up the nice related g.mapsets gui window.
>>> But still there are some power users which would like to avoid
>>> starting the main big GUI. Personally, I like the idea of accessing
>>> anything in the gui from command line (one reason is that it helps to
>>> reduce dependencies in the gui code).
>>> One solution would be run gui for modules such as r.in.gdal by some
>>> gui starter command which would accept the module name as a parameter;
>>> it is something like command line menu (g.gui.climenu). This was
>>> proposed for the g.gui.* in order to avoid having many new modules or
>>> to avoid the new kind of modules.
> +1
I don't think you need another gui starter command. What the parser is
doing right now is sufficient. The parser calls
gui/wxpython/gui_core/forms.py which in turn brings up the appropriate
interface. The only modification that is needed is make forms.py bring
up the customized interface. This solution would not require a special
flag and no special gui starter command. You would then fire up a
module from the command line without arguments and get the same
interface like when calling it from the gui menu.
Markus M
>> I am not sure if this needs emphasizing, but the customized GUI
>> interfaces already exist. The idea here is to call the already
>> existing customized interface for a given module, e.g.
>> r.in.gdal/v.in.ogr/r.colors/v.clean/i.group/g.mapsets etc. No funny
>> flag needed in the module.
> Much agreed :)
> markusN
