[GRASS-dev] [GRASS GIS] #1896: d.graph in console tries to add mapset
GRASS GIS trac at osgeo.org
Fri Feb 22 10:23:03 PST 2013
 Reporter:  cmbarton     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  wxGUI        |     Version:  unspecified
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 I just tried to use d.graph to display a legend made with
 d.thematic.chart.
 Here is the command: d.graph input=/Users/cmbarton/chartlegend
 Here is the error:
 Command 'd.graph
 input=/Users/cmbarton/chartlegend at spatialtech2012' failed
 Details: Graph file
 </Users/cmbarton/chartlegend at spatialtech2012> not found
 The console parsing algorithm is trying to add the mapset name to the text
 file with d.graph commands. This is in 7.0. It may also be a problem in
 other versions.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1896>
