[GRASS-dev] how to sample a series at one location?
Newcomb, Doug doug_newcomb at fws.gov
Fri Feb 22 12:43:43 PST 2013
t.create--> t.register--> t.vect.observer.strds   in GRASS7 ?   Looks
really nifty, could be useful with the Landsat Cube data sets
http://landsat.usgs.gov/documents/Oct27_29_2009_huang_LST_boston.ppt<view-source:http://landsat.usgs.gov/documents/Oct27_29_2009_huang_LST_boston.ppt>
Doug
On Fri, Feb 22, 2013 at 2:53 PM, Michael Barton <Michael.Barton at asu.edu>wrote:
>  Thanks Doug,
>  I knew I could do it with a script and v.what.rast.
>  What I was hoping was that there is a shortcut already usable in GRASS
> modules. Looks like the new temporal GIS tools may be able to do it.
>  Michael
>          ______________________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> Tempe, AZ  85287-2402
> USA
>  voice:  480-965-6262 (SHESC), 480-727-9746 (CSDC)
> fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
> www:  http://csdc.asu.edu, http://shesc.asu.edu
> http://www.public.asu.edu/~cmbarton
>  On Feb 22, 2013, at 12:31 PM, "Newcomb, Doug" <doug_newcomb at fws.gov>
>  wrote:
>  Michael,
> You could use v.what.rast  in a python script , iterating the raster
> layers with an sqlite database back end.  I think that would go up to 2000
> columns for each point you have.
>  Alternatively, you could use a bit of python with gdal.  I was trying to
> do something similar in GRASS, to change the Z value of each point in a
> text LiDAR file, from absolute above sea level to relative the elevation of
> the ground.  For 25.5 billion text points and a Statewide 20 ft elevation
> grid (6.5 ? billion cells) , it was a bit slow using r.what.  So I
> converted the LiDAR data to (7)  3.3 billion point  LAS format files and
> exported the GRASS layer to an Erdas imagine format file and wrote the
> following ugly python script:
>  #!/usr/bin/python
> import os,string,glob,re,gdal
> from liblas import file
> from liblas import header
> from liblas import point
> from gdalconst import *
> h=header.Header()
> #enter the LAS point file name
> infile=raw_input("Enter the input lidar data points file: ")
> #Hardcoded edras imagine file, you will have to use an array for the
> different data layer names
> imgfile="/gisdata2/raster/allnc_20ft_el.img"
> #print "suggest /gisdata2/raster for output dir\n"
> inarr=infile.split('.')
> #This sets the LAS output file, substitute your output text file instead
> outfil=inarr[0]+"_norm.las"
> #outfil=raw_input("Enter output text file name: ")
> #This part reads the LAS file, if you
> l=file.File(infile,mode='r')
> #Outputs the LAS file
> lout=file.File(outfil,mode='w',header=h)
> # register all of the drivers, hopefully your gdal speaks GRASS
> gdal.AllRegister()
> #opening and closing the image layers might take some time if you are
> reading thousands of images
> ds=gdal.Open(imgfile,GA_ReadOnly)
> if ds is None:
>     print 'Could not open image'
>     sys.exit(1)
> # get image size
> rows = ds.RasterYSize
> cols = ds.RasterXSize
> bands = ds.RasterCount
> # get georeference info, not sure how this would work for GRASS data layers
> transform = ds.GetGeoTransform()
> xOrigin = transform[0]
> yOrigin = transformAsArray(xOffset, yOffset, 1, 1)
> pixelWidth = transform[1]
> pixelHeight = transform[5]
>  for p in l:
>     x=float(p.x)
>     y=float(p.y)
>     z=float(p.z)
>     # compute pixel offset
>     xOffset = int((x - xOrigin) / pixelWidth)
>     yOffset = int((y - yOrigin) / pixelHeight)
>     band = ds.GetRasterBand(1) # 1-based index 0? 1?
>     data = band.Readr(value) :continue
>     value = data[0,0]
>     #print value,"11","\n"
>     if "nan" in st[3]
>     znorm = z-value
>     #print znorm,"\n"
>     pt=point.Point()
>     pt.x=p.x
>     pt.y=p.y
>     pt.z=znorm
>     lout.write(pt)
>  l.close()
> lout.close()
> #25561312019 points in allreturns
>  This managed to process everything over a weekend( in 7 parallel
> threads), which was fast enough for me at the time.  Approaching your
> problem , if your data layers are all n GRASS and your version of gdal can
> read GRASS data layers,  I would grab the list of GRASS layers via glob and
> iterate the layers , writing the name of the raster layer and the value of
> the raster layer at the point coordinates out to a text file as you state
> below.
>  Hope this helps,
> Doug
> On Fri, Feb 22, 2013 at 1:23 PM, Michael Barton <Michael.Barton at asu.edu>wrote:
>> But I want to do it with a time series of hundreds or thousands of maps.
>> Michael
>> C. Michael Barton
>> USA
>>  On Feb 22, 2013, at 10:53 AM, Markus Neteler <neteler at osgeo.org>
>>   wrote:
>> > On Fri, Feb 22, 2013 at 6:41 PM, Michael Barton <Michael.Barton at asu.edu>
>> wrote:
>> >> Is there tool somewhere, including in the new temporal GIS modules, to
>> >> sample the value of a raster series at one cell location? I'd like to
>> get
>> >> text something like this for a cell that I specify with xy coordinates
>> or a
>> >> cat:
>> >> map1, value 1
>> >> map2, value 2
>> >> map3, value 3
>> >> map4, value 4
>> >> map5, value 5
>> > I do such queries with r.what which accepts multiple input:
>> > http://grass.osgeo.org/grass64/manuals/r.what.html
>> > Markus
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Doug Newcomb
> USFWS
> Raleigh, NC
> 919-856-4520 ext. 14 doug_newcomb at fws.gov
> The opinions I express are my own and are not representative of the
> official policy of the U.S.Fish and Wildlife Service or Dept. of the
> Interior.   Life is too short for undocumented, proprietary data formats.
Doug Newcomb
USFWS
Raleigh, NC
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130222/ddd4281c/attachment-0001.html>
