[GRASS-dev] [GRASS GIS] #1270: wingrass: Error in Attribute Table Manager
GRASS GIS trac at osgeo.org
Mon Feb 25 12:31:19 PST 2013
 Reporter:  antonioall                         |       Owner:  grass-dev@…
     Type:  defect                             |      Status:  new
 Priority:  blocker                            |   Milestone:  6.4.3
Component:  wxGUI                              |     Version:  svn-develbranch6
 Keywords:  wingrass, attribute table manager  |    Platform:  MSWindows Vista
      Cpu:  x86-32                             |
Comment(by hellik):
 Replying to [comment:16 hamish]:
 > moreover, using v.db.addcol from the main db -> vect db conns menu to
 add a column had this error:
 > v.db.addcol --verbose map=copyofbugs2 at user1 columns=someint2 integer
 > DBMI-DBF driver error:
 > ERROR: Unable to open database <C:/Program Files (x86)/GRASS GIS
 6.4.3svn/msys/Users/Hamish/Documents/GIS DataBase/spearfish60/user1/dbf/>
 > ERROR: Cannot continue (problem adding column).
 and now tested with the wingrass-standalone installer
 GRASS version: 6.4.3svn
 GRASS SVN Revision: 55185
 GIS Library Revision: 50937 (2012-02-25)
 GDAL/OGR: GDAL 1.9.2, released 2012/10/08
 PROJ4: Rel. 4.8.0, 6 March 2012
 Python: 2.7.2
 wxPython: 2.8.12.1
 Platform: Windows-7-6.1.7601-SP1
 v.db.addcol map=myhosp at user1 columns=someint3 integer
 (Mon Feb 25 21:28:45 2013) Command finished (2 sec)
 Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1270#comment:20>
