[GRASS-dev] [GRASS GIS] #1889: wxPy loc'n wiz: don't auto-launch into PERMANENT
GRASS GIS trac at osgeo.org
Wed Feb 27 05:23:51 PST 2013
 Reporter:  hamish           |       Owner:  grass-dev@…
     Type:  defect           |      Status:  new
 Priority:  blocker          |   Milestone:  6.4.3
Component:  wxGUI            |     Version:  6.4.3 RCs
 Keywords:  location wizard  |    Platform:  Unspecified
      Cpu:  x86-64           |
Comment(by glynn):
 Replying to [comment:10 wenzeslaus]:
 > In r55231 I added some doc for r55229 but actually, I don't understand
 the issue completely. I know about ticked #1293 and I can see that
 functions G_legal_filename or G_check_input_output_name (file
 legal_name.c) are used only on a few places (according to grep and
 programming manual). There is some check in G_parser function because it
 is not possible to create map with dot or slash but probably
 G_legal_filename is not used. (There is a warning which is reported twice
 but that is another issue.)
 G_parser() doesn't check for legal file names. However, G_open() etc do,
 and those functions are used by Rast_open_new() etc.
 > I've tried to create map with non-latin characters but I'm not able to
 do it.
 Bytes above 126 aren't allowed in filenames. That excludes the DEL
 character as well as all non-ASCII characters, regardless of the encoding.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1889#comment:11>
