[GRASS-dev] [GRASS GIS] #1844: wingrass: db_open_select_cursor fails for DBF driver.
GRASS GIS trac at osgeo.org
Thu Jan 3 06:59:26 PST 2013
 Reporter:  martinl        |       Owner:  grass-dev@…
     Type:  defect         |      Status:  new
 Priority:  critical       |   Milestone:  6.4.3
Component:  Database       |     Version:  unspecified
 Keywords:  wingrass, dbf  |    Platform:  MSWindows 2K
      Cpu:  Unspecified    |
 There is problem with DBF driver on MS Windows. To reproduce this bug run:
 db.connect driver=dbf database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/'
 v.random out=n n=3
 v.db.addtable map=n columns="class varchar(10)"
 It stops at source:grass/trunk/lib/db/dbmi_client/c_openselect.c#L63
 D3/5: db_select_int()
 D3/5:   SQL: SELECT cat FROM n
 D3/5: SQL statement parsed successfully: SELECT cat FROM n
 D2/5: find_table(): table = n
 D2/5:   ? n
 D2/5: load_table_head(): tab = 0,
 /opt/grassdata/nc_spm_08_grass7/dbf/dbf//n.dbf
 D2/5:   ncols = 2
 D2/5:   DBFFieldType 1
 D3/5: add_column(): tab = 0, type = 2, name = cat, width = 11, decimals =
 0
 D2/5:   DBFFieldType 0
 D3/5: add_column(): tab = 0, type = 1, name = class, width = 10, decimals
 = 0
 D3/5: Doing SQL command <4> on DBF table... (see include/sqlp.h)
 D2/5: SELECT
 D2/5: sel(): tab = 0
 D2/5: load_table(): tab = 0
 D2/5:   ncols = 2 nrows = 0
Ticket URL: <http://trac.osgeo.org/grass/ticket/1844>
