[GRASS-dev] Grass7 GUI compilation failed
Rashad M mohammedrashadkm at gmail.com
Fri Jan 4 02:42:56 PST 2013
this patch solved gui compilation problem for me in Ubuntu12.04. There
maybe a better way to do the trick. But this works
On Mon, Dec 31, 2012 at 12:49 AM, Michael Barton <Michael.Barton at asu.edu>wrote:
> I doubt that it is the animation modules itself. But at about the time
> this was added, there was some change in related code (could be a class in
> one of the g.gui.* modules, or maybe something else). This it is changes
> that started around this time and affecting previously working modules for
> mapswipe and modeler--and now other modules. Something was switched so that
> these now call something that they did not call before that time and that
> is breaking GRASS compilation on the Mac.
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> voice:  480-965-6262 (SHESC), 480-727-9746 (CSDC)
> fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Dec 29, 2012, at 10:30 PM, Helena Mitasova <hmitaso at ncsu.edu>
>  wrote:
> > I can confirm that - I don't think it was the animation, I think it was
> the g.gui.* that started to break down modules for me.
> > I am still on 10.6.8 but I am trying to set up a machine with 10.8 for
> testing.
> > Currently, the compilation ends with error for the following modules:
> > /Users/helena/grassdev7/grass_trunk/gui/wxpython/animation
> > /Users/helena/grassdev7/grass_trunk/gui/wxpython/mapswipe
> > /Users/helena/grassdev7/grass_trunk/gui/wxpython/gmodeler
> > /Users/helena/grassdev7/grass_trunk/gui/wxpython/rlisetup
> > /Users/helena/grassdev7/grass_trunk/gui/wxpython/psmap
> > /Users/helena/grassdev7/grass_trunk/gui/wxpython/dbmgr
> > /Users/helena/grassdev7/grass_trunk/gui/wxpython/vdigit
> > /Users/helena/grassdev7/grass_trunk/gui/wxpython/iclass
> > but it affects more than the modules above - for example switching to 3d
> view is broken - it has erratic behavior (I can provide
> > more details - there are too many to list here but the following error
> shows up
> > pythonw2.6[69774] <Error>: CGContextRestoreGState: invalid context 0x0
> > (this is just with a single DEM, no volumes)
> > v.digit runs but hangs on rendering
> > mapswipe works fine except for the manual page which gives
> > animation tool does not start at all giving the following error
> > CGBitmapContextCreate: invalid data bytes/row: should be at least 4 for
> 8 integer bits/component, 3 componen
> > ts, kCGImageAlphaNoneSkipFirst.
> > pythonw2.6[69774] <Error>: CGContextTranslateCTM: invalid context 0x0
> > pythonw2.6[69774] <Error>: CGContextScaleCTM: invalid context 0x0
> > Note that  this issue is different from GRASS6.4.3
> > crashing gui on OS X 10.7 and 10.8 when drawing isosurfaces - that works
> OK on 10.6 but the issues above
> > are in GRASS7 only and on Mac OSX 10.6 - 10.8
> > Helena
> > On Dec 29, 2012, at 3:57 PM, Michael Barton wrote:
> >> This has been broken since the introduction of the animation module and
> apparently now is affecting other modules that used to compile fine. So
> GRASS 7 is increasingly broken for the Mac. Volume displays have been
> broken for many months now. If someone could tell me what has changed with
> the introduction of these new modules and related changes to the other
> ones, I might be able to find out what is breaking on the Mac. I'm guessing
> that it is a new class that calls some wxPython windowing routine that has
> a problem, but I don't know what it is.
> >> Michael
> >> C. Michael Barton
> >> On Dec 29, 2012, at 1:00 PM, <grass-dev-request at lists.osgeo.org>
> >> wrote:
> >>> From: Rashad M <mohammedrashadkm at gmail.com>
> >>> Subject: Re: [GRASS-dev] Grass7 GUI compilation failed
> >>> Date: December 29, 2012 11:25:17 AM MST
> >>> To: <grass-dev at lists.osgeo.org>
> >>> here is output from v.digit
> >>> make
> >>> ml
> >>> make[6]: Entering directory `/code/grass/grass70/gui/wxpython/vdigit'
> GISRC=/code/grass/grass70/dist.x86_64-unknown-linux-gnu/demolocation/.grassrc70
> GISBASE=/code/grass/grass70/dist.x86_64-unknown-linux-gnu
> PATH="/code/grass/grass70/dist.x86_64-unknown-linux-gnu/bin:/code/grass/grass70/dist.x86_64-unknown-linux-gnu/bin:$PATH"
> PYTHONPATH="/code/grass/grass70/dist.x86_64-unknown-linux-gnu/etc/python:/code/grass/grass70/dist.x86_64-unknown-linux-gnu/etc/python:$PYTHONPATH"
> LD_LIBRARY_PATH="/code/grass/grass70/dist.x86_64-unknown-linux-gnu/bin:/code/grass/grass70/dist.x86_64-unknown-linux-gnu/lib:/code/grass/grass70/dist.x86_64-unknown-linux-gnu/lib:"
>  LC_ALL=C
> /code/grass/grass70/dist.x86_64-unknown-linux-gnu/scripts/g.gui.vdigit
> --html-description < /dev/null | grep -v '</body>\|</html>' >
> g.gui.vdigit.tmp.html
> >>> Traceback (most recent call last):
> >>>  File
> "/code/grass/grass70/dist.x86_64-unknown-linux-gnu/scripts/g.gui.vdigit",
> line 39, in <module>
> >>>    import wx
> >>> ImportError: No module named wx
> >>> make[6]: *** [g.gui.vdigit.tmp.html] Error 1
> >>> rm g.gui.vdigit.tmp.html
> >>> make[6]: Leaving directory `/code/grass/grass70/gui/wxpython/vdigit'
> >>> make[5]: *** [guiscript] Error 2
> >>> On Sat, Dec 29, 2012 at 9:57 PM, Rashad M <mohammedrashadkm at gmail.com>
> wrote:
> >>> grass7.0 fails compilation at first and continues only after setting
> PYTHONPATH.
> >>> This becomes a routine for recompilation. Is there any work around to
> automatically pickup wxPython?
> >>> Here is my error log:
> >>> Started compilation: Sat Dec 29 21:46:17 IST 2012
> >>> Errors in:
> >>> /code/grass/grass70/gui/wxpython/animation
> >>> /code/grass/grass70/gui/wxpython/mapswipe
> >>> /code/grass/grass70/gui/wxpython/gmodeler
> >>> /code/grass/grass70/gui/wxpython/rlisetup
> >>> /code/grass/grass70/gui/wxpython/psmap
> >>> /code/grass/grass70/gui/wxpython/dbmgr
> >>> In case of errors please change into the directory with error and run
> 'make'.
> >>> If you get multiple errors, you need to deal with them in the order
> they
> >>> appear in the error log. If you get an error building a library, you
> will
> >>> also get errors from anything which uses the library.
> >>> Finished compilation: Sat Dec 29 21:53:10 IST 2012
> >>> wxpython is installed from ubuntu repos. so its in the default path
> >>> Regards,
> >>>   Rashad
> >>> Regards,
> >>>   Rashad
> >> _______________________________________________
> >> grass-dev mailing list
> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130104/13c294ea/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130104/13c294ea/attachment.obj>
