[GRASS-dev] d.correlate not working
Anna Kratochvílová kratochanna at gmail.com
Sun Jan 13 08:19:44 PST 2013
On Sat, Jan 12, 2013 at 10:43 AM, Rashad M <mohammedrashadkm at gmail.com> wrote:
> using:
> grass  7.0
> revision:54601
> d.correlate is not working
> To reproduce
> d.mon wx0
> d.correlate map=lsat5_1987_10,lsat5_1987_20
> error:
> GRASS_INFO_WARNING(25298,1): Illegal filename
> <landsat,lsat5_1987_20 at landsat>. Character <,> not allowed.
> GRASS_INFO_END(25298,1)
> GRASS_INFO_WARNING(25314,1): Illegal filename
> GRASS_INFO_END(25314,1)
> Traceback (most recent call last):
>   File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_misc.py",
> line 1358, in Notify
>     self.notify()
>   File "/usr/local/grass-7.0.svn/etc/gui/wxpython/mapdisp/main.py", line
> 290, in watcher
>     self.mapFrm.GetMap().GetLayersFromCmdFile()
> 102, in GetLayersFromCmdFile
>     self.AddLayer(ltype = ltype, command = cmd, active = False, name = name)
>   File "/usr/local/grass-7.0.svn/etc/gui/wxpython/core/render.py", line
> 1042, in AddLayer
>     active = active, hidden = hidden, opacity = opacity)
>   File "/usr/local/grass-7.0.svn/etc/gui/wxpython/core/render.py", line 339,
> in __init__
>     active, hidden, opacity)
>   File "/usr/local/grass-7.0.svn/etc/gui/wxpython/core/render.py", line 88,
> in __init__
>     self.SetType(ltype)
>   File "/usr/local/grass-7.0.svn/etc/gui/wxpython/core/render.py", line 268,
> in SetType
>     raise GException(_("Unsupported map layer type '%s'") % ltype)
> core.gcmd.GException: Unsupported map layer type 'None'
Some of d. commands are not supported yet in wxGUI but at least you
can try to add them as a command layer in Layer Manager, it is in the
'Add grid or vector overlays' (perhaps it should be 'Add miscellaneous
overlays').
Anna
> Regards,
>    Rashad
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
