[GRASS-dev] Script for converting degrees clockwise from North to GRASS convention
Margherita Di Leo dileomargherita at gmail.com
Wed Jan 23 04:59:30 PST 2013
Hi Moritz,
thank you for your reply,
On Wed, Jan 23, 2013 at 12:21 PM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
>> If we call WIND the direction map which uses the convention degrees
>> clockwise from North, and GRASS the output map, the rule that I applied
>> is:
>> IF 0 <= WIND < 270     ;     GRASS = 270 - WIND
>> IF WIND = 270            ;      GRASS = 360
>> IF 270 < WIND < 360   ;      GRASS 630 - 0
>> IF WIND = null             ;     GRASS = 0
>> NULL otherwise (this latter I have added to check if there is any error.
> This is not correct.
> WIND = 0 means North.
Actually this was tricky also for me, but:
Wind direction is measured in:
   degrees clockwise from uphill (direction the wind is pushing the fire)
   degrees clockwise from North (direction the wind is blowing from)
If the wind is blowing FROM north, it means that the arrow is TOWARDS
south.. Am I wrong?
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Institute for Environment and Sustainability (IES). Unit H03 – FRC
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo at jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not
in any circumstance be regarded as stating an official position of the
European Commission.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130123/5df8df71/attachment.html>
