[GRASS-dev] [GRASS-SVN] r54770 - grass-addons/grass6/raster/r.mess
Paulo van Breugel p.vanbreugel at gmail.com
Mon Jan 28 00:48:58 PST 2013
Hi
Thanks Markus for pointing me out the email from Hamish about
"[GRASS-dev] g.extension not working on debian - grass 6.4.3svn". It did
help me to make some progress.
If I understand correctly, I should find the g.html2man script in
usr/local/grass6.4.current/tools. It is not however, it is still in
usr/local/grass6.4.current/tools/g.html2man subdirectory. This is after
a completely clean install (i.e., I removed grass6 completely from my
system, svn checkout was done from a totally clean (new) dir).
Installing extensions is no problem, but the manual page is not properly
created as described in my earlier email: the manual page is shown in
the addons GUI, but without the parameter sections (i.e., only the part
which is in the description.html).
Perhaps also relevant, if I run the "Uninstall GRASS Addon extension",
it shows no extensions installed. Removing using g.extension is also not
possible.
Now, if (1)  remove all extensions manually, (2) manually move the
g.html2man from tools/g.html2man to tools, (3) reinstall the extensions
(see install message below), then: the problem persists, the manual page
is still incomplete. However, now when running the "Uninstall GRASS
Addon extension" shows the installed extensions.
Install message: less error messages after moving the g.html2man to tools:
Fetching <r.mess> from GRASS-Addons SVN (be patient)...
Compiling...
/usr/local/grass6.4.current/grass-6.4.3svn/include/Make/Script.make:47: warning: overriding commands for target `install'
/usr/local/grass6.4.current/grass-6.4.3svn/include/Make/Rules.make:99: warning: ignoring old commands for target `install'
ERROR: G_getenv(): Variable LOCATION_NAME not set
/bin/sh: 1: cannot create /usr/local/grass6.4.current/grass-6.4.3svn/locale/scriptstrings/r.mess_to_translate.c: Directory nonexistent
Installing...
Updating metadata file...
Installation of <r.mess> successfully finished
Best wishes
Paulo
On 01/27/2013 11:26 PM, Paulo van Breugel wrote:
> Hi Markus,
> I am running Ubuntu 12.10. I am not sure what that means, g.extension
> being used outside of a GRASS session?
> I could perhaps also be related to how I installed grass? Below my set
> of .configure - make - make install and some further details (not sure
> they are useful info, but adding just in case).
> ./configure --enable-64bit --prefix=/usr/local/grass6.4.current
> --with-sqlite --with-postgres
> --with-postgres-libs=/usr/include/postgresql/libpq
> --with-postgres-includes=/usr/include/postgresql --with-odbc
> --with-geos --with-cairo --with-cxx=yes
> --with-gdal=/usr/local/gdal1.9/bin/gdal-config --with-libs=/lib64
> --with-python=yes --with-wxwidgets=/usr/bin/wx-config
> --with-tcltk-includes=/usr/include/tcl8.5 --with-readline
> --with-freetype --with-freetype-includes=/usr/include/freetype2
> --enable-largefile --with-motif --with-motif-includes=/usr/include
> --with-proj-share=/usr/share/proj
> make
> sudo make install
> I also created a shortcut in the /usr/bin: sudo ln -s
> /usr/local/grass6.4.current/bin/grass64 /usr/bin/grass6.4 + Added a
> configuration file in /etc/ld.so with the following line:
> /usr/local/grass6.4.current/grass-6.4.3svn/lib.
> Your help is much appreciated. I am happy it all runs, so this isn't a
> major issue, but it would obviously be good if I could solve this.
> On Sun, Jan 27, 2013 at 9:16 PM, Markus Neteler <neteler at osgeo.org
> <mailto:neteler at osgeo.org>> wrote:
>     On Sun, Jan 27, 2013 at 2:23 PM, Paulo van Breugel
>     <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> wrote:
>     > Hi Markus,
>     > Thanks for looking into this. It didn't work in first instance,
>     but after a
>     > completely clean install it works,
>     (yes, g.extension in GRASS 6 doesn't handle properly the case of
>     reinstallation)
>     > with one caveat. The help file shows now,
>     > but without the parameter info (which supposedly should be
>     extracted from
>     > the script?).
>     Yes, caused by the error below:
>     > I am also getting the following error message:
>     > Compiling...
>     To me it looks like g.extension being used outside of a GRASS session.
>     > I tried a few other extensions, and the same happens, so this
>     does not seem
>     > to be something specific to r.mess
>     On Fedora 17 no problem, it installs properly.
>     > (but I don't know if it is something specific to my system?).
>     Apparently yes: which OS is it?
>     Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130128/beac93f2/attachment.html>
