[GRASS-dev] [GRASS GIS] #1866: broken SQLite driver in winGRASS 7
GRASS GIS trac at osgeo.org
Thu Jan 31 03:49:01 PST 2013
 Reporter:  martinl           |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  blocker           |   Milestone:  7.0.0
Component:  Database          |     Version:  unspecified
 Keywords:  sqlite, wingrass  |    Platform:  MSWindows 2K
      Cpu:  Unspecified       |
 In winGRASS 7 also SQLite driver is not working (see #1844 from DBF
 driver). NC (basic) dataset.
 db.describe census
 doesn't report any error, it just hangs. Adding some extra debug messages,
 I found the line when it stops. It's
 source:grass/trunk/lib/db/dbmi_base/xdrcolumn.c#L56. First three columns
 are retrieved (cat, OBJRCTID, AREA). It stops on fourth column and waiting
 for response.
 Any idea where could be a problem?
 This bugs affects only GRASS 7, SQLite driver in GRASS 6 seems to work.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1866>
