[GRASS-dev] [GRASS GIS] #2036: Failed watershed analysis on Grass
GRASS GIS trac at osgeo.org
Thu Jul 18 13:47:52 PDT 2013
  Reporter:  mehmeto      |       Owner:  grass-dev@…
      Type:  defect       |      Status:  closed
  Priority:  normal       |   Milestone:  6.4.4
 Component:  Raster       |     Version:  6.4.2
Resolution:  fixed        |    Keywords:  LFS, r.watershed
  Platform:  MSWindows 7  |         Cpu:  x86-64
Changes (by mehmeto):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Tried to do the same analysis with Spearfish data that also is in the
 installation package and it worked. It should be a memory problem indeed.
 (although Spearfish map looks larger) Thanks for your replies.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2036#comment:6>
