[GRASS-dev] d.rast3d not launching on windows
Anna Petrášová kratochanna at gmail.com
Sat Jul 20 12:06:49 PDT 2013
On Thu, Jul 18, 2013 at 11:30 PM, Hamish <hamish_b at yahoo.com> wrote:
> Anna wrote:
> > I get this error when launching d.rast3d from layer manager
> > toolbar on Windows.
> > I fixed it in r57218 [1] but it I was wondering if there is
> > some better solution?
> > Traceback (most recent call last):
> > Unable to fetch interface description for command 'd.rast3d.py'.
> > [1] http://trac.osgeo.org/grass/changeset/57218
> > os.chdir(...)
> Hi,
> the "Unable to fetch interface description for command" error is typically
> because the g.parser script-handling module can not find the script that
> called it in the system $PATH.
> (error message happens in lib/python/script/task.py)
> The os.chdir() solution may work on Windows since "." is usually in %PATH%
> there, but on Unix "." is typically not in your path.
> I think it's better remove the os.chdir()s and replace them by adding
> $GISBASE/etc/gui/scripts/ to the PATH when the wxGUI first starts up.
> Going into the grass7 wxGUI's Python shell tab, and import os,
> os.getenv('PATH') shows the last entry as etc/gui/scripts/ already.
> (tested on linux)    :-/ so that might not be it.
the command is launched with python executable:
.../python.exe d.rast3d.py
so it seems that it expects the full path to the script and therefore chdir
before it made it work.
$GISBASE/etc/gui/scripts/  is already on the PATH.
> On linux the script is installed as "d.rast3d" without the .py, I guess
> it keeps the .py extension on Windows? perhaps check how the script is
> called: is e.g. 'd.rast3d.py' requested but 'd.rast3d' found?
there should be d.rast3d.py which is really there so that's not the problem.
So we can keep this solution until someone finds something better.
Thanks,
Anna
> Maybe etc/gui/scripts/ needs to be added to PYTHONPATH with
> wxscripts = os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'scripts')
> if wxbase not in sys.path:
>     sys.path.append(wxbase)
> (probably won't help, but worth a try)
> Hamish
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130720/7c827816/attachment.html>
