[GRASS-dev] [GRASS GIS] #1866: broken db driver communication in winGRASS 7
GRASS GIS trac at osgeo.org
Wed Jul 24 05:36:12 PDT 2013
 Reporter:  martinl           |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  blocker           |   Milestone:  7.0.0
Component:  Database          |     Version:  unspecified
 Keywords:  sqlite, wingrass  |    Platform:  MSWindows 2K
      Cpu:  Unspecified       |
Comment(by neteler):
 Replying to [comment:41 mlennert]:
 > Replying to [comment:39 mlennert]:
 > > Replying to [comment:38 neteler]:
 > > > Replying to [comment:34 hamish]:
 > > > > Replying to [comment:33 neteler]:
 > > > > > I have tried with r56943 on Windows8, still failing:
 > > > > > GRASS 7.0.svn> db.describe overpasses
 > > > > is the overpass vector map in the current mapset?
 No. I tried from the user1 mapset.
 > > > > You may be seeing the effect of the db.* modules only working for
 databases linked from maps in the current mapset
 Right. So we need a test for that rather than failing with a slightly
 obscured error message. Or expand it to say:
 "Table <%s> not found in current mapset"
 > > Does it really hang, or does it fail and give back the prompt after
 the error message ?
 No, it comes back to the command line just checked again with a current
 OSGeo4W-GRASS 7.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1866#comment:42>
