[GRASS-dev] [GRASS GIS] #2042: wxgui: no more menu access to r.in.gdal / v.in.ogr
GRASS GIS trac at osgeo.org
Thu Jul 25 05:23:31 PDT 2013
 Reporter:  mlennert                |       Owner:  grass-dev@…
     Type:  defect                  |      Status:  new
 Priority:  normal                  |   Milestone:  7.0.0
Component:  wxGUI                   |     Version:  svn-trunk
 Keywords:  r.in.gdal v.in.ogr gui  |    Platform:  Unspecified
      Cpu:  Unspecified             |
 In GRASS 6, when you use the File->Import raster data->Common formats
 import wizard frontend to r.in.gdal (or its equivalent for v.in.ogr), you
 have a button that allows you to launch the actual module GUI, instead of
 the wizard frontend.
 In GRASS7 that button has disappeared. Why ? Now the user cannot reach
 that module gui via the menus anymore, but only by typing the module name
 in the terminal or console. I find this a regression as sometimes, being
 able to switch to the module gui is helpful.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2042>
