[GRASS-dev] Python handling in winGRASS7 [was: Re: GRASS GIS 7 tech-preview release preparations]
Moritz Lennert mlennert at club.worldonline.be
Fri Jul 26 08:59:31 PDT 2013
On 26/07/13 17:10, Helmut Kudrnovsky wrote:
>> IMHO the question is/will be: is there a robust mechanism for calling a
> script from a script and making>addons easily callable by the embedded
> python interpreter working on WinXp, WinVista, Win7 and Win8?
>> if this is working robustely, I think we are on a good way for a nice
> (python) usable WinGrass6/7... :o)
> maybe there could be some hints to solve this?:
> Python launcher for Windows
> http://www.python.org/dev/peps/pep-0397/
This refers to the Python launcher that Glynn mentioned half a year ago:
http://lists.osgeo.org/pipermail/grass-dev/2013-January/061466.html
The launcher is explained here:
http://docs.python.org/3/using/windows.html#launcher
It actually allows the use of shebang lines:
http://docs.python.org/3/using/windows.html#shebang-lines
And it allows to create a py.ini file to customize the way Python is
called. A version of that file in the "Application data" directory
overrides systemwide settings, so I guess we could use something like
that to customise if shebangs are not enough:
http://docs.python.org/3/using/windows.html#customization
In my limited understanding this actually sounds like a very promising
solution which avoids having to treat Windows in a very different way.
shebangs with '/usr/bin/env python' might allow us to solve the issue.
Moritz
