[GRASS-dev] [GRASS GIS] #2039: Startup Error
GRASS GIS trac at osgeo.org
Mon Jul 29 12:18:30 PDT 2013
 Reporter:  akdeakin  |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  6.4.4
Component:  Startup   |     Version:  6.4.3 RCs
 Keywords:  wingrass  |    Platform:  MSWindows 7
      Cpu:  x86-64    |
Comment(by hellik):
 Replying to [comment:9 mlennert]:
 > Could someone check what exact version ArcGIS installs. I suspect <
 2.7.4.
 have a look at http://trac.osgeo.org/grass/ticket/2015#comment:6
 => it's the system wide python 2.7.2 installed by ArcGIS10.1.
 > Unfortunately, the Python launcher discussed in the thread Helmut points
 to in comment:7 seems to only take into account minor version numbers, but
 not revision numbers, so there does not seem to be a way to distinguish
 between two versions of 2.7 on the machine.
 see also http://trac.osgeo.org/grass/ticket/2015#comment:6
 > Is it possible to uninstall the python installed by ESRI ?
 only if you deinstall ArcGIS ...
 > One option would probably be to delete the registry key entries of the
 ESRI Python version, install a more recent Python (e.g. 2.7.5) and install
 the Python launcher.
 but then ArcGIS is unusable ... ok, it's not open source ... ;o)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2039#comment:10>
