[GRASS-dev] Subgroups in i.segment
Markus Metz markus.metz.giswork at gmail.com
Sat Jun 1 02:04:44 PDT 2013
On Fri, May 31, 2013 at 10:06 PM, Nikos Alexandris
<nik at nikosalexandris.net> wrote:
> Recently I did some tests (with Pietro Z) using "i.segment" on an RGB
> orthophoto sample.  If am not wrong, the module works with "groups" only.
Correct.
> Driven by the discussion
> "ticket #1984: i.pca should accept also group names as input (like
> r.out.gdal)"
> I wonder whether the module will support subgroups at some point as well.
Could be, if someone finds the time to implement it...
Markus M
