[GRASS-dev] Unexpected "v.db.select separator=newline" output
Nikos Alexandris nik at nikosalexandris.net
Tue Jun 4 14:41:22 PDT 2013
Martin Landa wrote:
> Hi,
> 2013/6/4 Nikos Alexandris <nik at nikosalexandris.net>:
> >         v.db.select mangrove_sites_coordinates_latest
col=cat,wrspr
> > separator=newline | head
> > catnewlinewrspr
> > 1newline161043
> > 2newline161043
> should be fixed in r56593. Martin
Thank you for your time Martin,
it works with
g.version -r
GRASS 7.0.svn (2013)
libgis Revision: 56211
libgis Date: 2013-05-12 14:07:51 +0300 (Sun, 12 May 2013)
However, the "-v" flag is still broken, e.g.:
v.db.select -cv mangrove_sites_coordinates_latest col=cat,wrspr
separator=space vs=comma | head
1
161043
comma
2
161043
comma
3
161043
comma
4
Cheers, N
