[GRASS-dev] Unexpected "v.db.select separator=newline" output
Moritz Lennert
mlennert at club.worldonline.be
Wed Jun 5 03:15:23 PDT 2013
On 05/06/13 11:14, Martin Landa wrote:
> Hi,
> 2013/6/4 Nikos Alexandris<nik at nikosalexandris.net>:
>> However, the "-v" flag is still broken, e.g.:
>> v.db.select -cv mangrove_sites_coordinates_latest col=cat,wrspr
>> separator=space vs=comma | head
>> 1
>> 161043
>> comma
> ops, I overlooked this issue, should be fixed in r56597. Martin
I think what Nikos is trying to get as a result would rather need a
change such as this:
Index: main.c
--- main.c (révision 56597)
+++ main.c (copie de travail)
@@ -264,7 +264,10 @@
else {
if (!v_flag->answer)
- fprintf(stdout, "\n");
+ if(vs)
+ fprintf(stdout, "%s", vs);
+ else
+ fprintf(stdout, "\n");
else if (vs)
fprintf(stdout, "%s\n", vs);
which gives you:
> v.db.select hospitals col=cat vs=,
cat
1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100,101,102,103,104,105,106,107,108,109,110,111,112,113,114,115,116,117,118,119,120,121,122,123,124,125,126,127,128,129,130,131,132,133,134,135,136,137,138,139,140,141,142,143,144,145,146,147,148,149,150,151,152,153,154,155,156,157,158,159,160,
Just needs some cleanup to get rid of the last ',' at the end.
Moritz
