[GRASS-dev] GRASS 6.4.3 release planning
Michael Barton michael.barton at asu.edu
Wed Jun 5 13:08:50 PDT 2013
I just was able to test g.extension on GRASS 7 compiled yesterday. I tried it with r.fuzzy because (IIRC) Markus said it is not broken and should install.
Unfortunately, it does not yet work. Here is the error. Note that the demolocation is NOT my default or explicitly specified install location ($GRASS_ADDON_BASE is /Users/cmbarton/Library/GRASS/7.0/Modules).
g.extension extension=r.fuzzy operation=add
Fetching <r.fuzzy> from GRASS-Addons SVN (be patient)...
Compiling...
main.c: In function 'main':
main.c:152: warning: format not a string literal and no
format arguments
main.c:156: warning: format not a string literal and no
format arguments
format arguments
format arguments
access: No such file or directory
ERROR: LOCATION </Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.3.0/demolocation> not available
make[1]: *** [r.fuzzy.set.tmp.html] Error 1
make[1]: *** [r.fuzzy.logic.tmp.html] Error 1
main.c:151: warning: format not a string literal and no
format arguments
main.c:155: warning: format not a string literal and no
format arguments
main.c:157: warning: format not a string literal and no
format arguments
format arguments
format arguments
format arguments
map_parser.c: In function 'parse_map_file':
map_parser.c:92: warning: format not a string literal and no
format arguments
format arguments
rule_parser.c: In function 'parse_rules':
rule_parser.c:132: warning: format not a string literal and
no format arguments
no format arguments
make[1]: *** [r.fuzzy.system.tmp.html] Error 1
Installing...
make: *** No rule to make target `install'.  Stop.
WARNING: Installation failed, sorry. Please check above error messages.
(Wed Jun  5 13:05:17 2013) Command finished (4 sec)
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 	480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On May 25, 2013, at 12:04 PM, epi <massimodisasha at gmail.com> wrote:
> Hi All,
> i just tried to build grass6_release from the svn  grass64 svn, Revision: 56411
> build is fine, no  errors detected, but without  GUI (wx or tcltk are not working in my case,  montain lion 64 bit build ***)
> to test the extension build i tried :
> g.extension extension=i.landsat.dehaze
> and it worked without errors.
> note :
> from the g.extension page the example point  to i.landsat.toar (now included as default in grass) we should change it.
> i was wondering if the WXgui changes in grass7,  to have it running with wx2.9-cocoa
> can be back ported to grass6.x .. is this possible ?
> thank you,
> Massimo
> Il giorno 25/mag/2013, alle ore 12:05, William Kyngesburye <woklist at kyngchaos.com> ha scritto:
>> On May 25, 2013, at 5:31 AM, Markus Neteler wrote:
>>>> #854: building addons on Mac (assume we can handle post-release in pkg'ing)
>>>> --what's the situation?
>>> Commonly our Mac packagers package the release (candidate) versions,
>>> so we'll know ex-post only.
>> I had some time to look at this, and it should be fixed now, for 6.4 at least.  (Mac makefile was out of sync with the main makefile)
>> Michael, if you're back or have dev Mac available, (and Hamish, do you have a Mac to try?) - can you verify it works for you?
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "Mon Dieu! but they are all alike.  Cheating, murdering, lying, fighting, and all for things that the beasts of the jungle would not deign to possess - money to purchase the effeminate pleasures of weaklings.  And yet withal bound down by silly customs that make them slaves to their unhappy lot while firm in the belief that they be the lords of creation enjoying the only real pleasures of existence....
>> - the wisdom of Tarzan
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
