[GRASS-dev] GRASS 6.4.3 release planning
Michael Barton michael.barton at asu.edu
Wed Jun 5 13:40:07 PDT 2013
The problem with this path...
>> LOCATION </Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.3.0/demolocation> not available
...is that it assumes that the user has the source distribution. This path does not exist with a binary-only distribution.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 	480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Jun 5, 2013, at 1:37 PM, Markus Neteler <neteler at osgeo.org>
 wrote:
> On Wed, Jun 5, 2013 at 10:08 PM, Michael Barton <michael.barton at asu.edu> wrote:
>> I just was able to test g.extension on GRASS 7 compiled yesterday. I tried it with r.fuzzy because (IIRC) Markus said it is not broken and should install.
>> Unfortunately, it does not yet work. Here is the error. Note that the demolocation is NOT my default or explicitly specified install location ($GRASS_ADDON_BASE is /Users/cmbarton/Library/GRASS/7.0/Modules).
> It seems that demolocation is not found? It is used in the virtual session
> set up during the compilation process which fails below:
>> g.extension extension=r.fuzzy operation=add
>> Fetching <r.fuzzy> from GRASS-Addons SVN (be patient)...
>> Compiling...
>> main.c: In function 'main':
>> ERROR: LOCATION </Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.3.0/demolocation> not available
> Is it possible that the copying of demolocation to that target is not
> happening on Mac? It is actually needed.
> Markus
