[GRASS-dev] [GRASS GIS] #1978: module GUIs: "or enter values interactively" should be opt-in
GRASS GIS trac at osgeo.org
Sat Jun 8 02:17:19 PDT 2013
 Reporter:  hamish  |       Owner:  grass-dev@…
     Type:  defect  |      Status:  new
 Priority:  normal  |   Milestone:  6.4.4
Component:  wxGUI   |     Version:  svn-trunk
 Keywords:  parser  |    Platform:  All
      Cpu:  All     |
Comment(by hamish):
 If term 2 (element) is "file", trunk's libgis checks to see if the file
 already exists & insists on --overwrite. So for file input= and output=
 term 2 should probably stay as "file".  This also means that the GUI
 should use term 2 (element) to decide if there should be a file [Browse]
 button present, instead of term 3 (prompt/description) as it does now.
 term 1 remains "old", "new"; the value of "any" doesn't seem to be used
 any more in g6.4+ or g7.
 so that leaves the switch for deciding on a text input box to be based on
 the third term (prompt/description). (as far as
 gui/wxpython/gui_core/forms.py is concerned)
 so e.g. for r.in.mat we have this info from --interface-description
  <gisprompt age="old" element="mat" prompt="file" />
 `element` would go back to "file", and term 3, `prompt` (aka description),
 would change from "file" to "text" (or "bin" or generic "file").
 And the "or enter text interactively" box would be made to only show up if
 `prompt` was "text".
 In GRASS 6 with GRASS_UI_TERM set, the `prompt` term 3 is used in the
 "Enter the name of" line, as is term 1's "new". e.g. for r.in.bin it is
 {input}:
 OPTION:   Binary raster file to be imported
      key: input
 required: YES
 Enter the name of an existing {input} file
 Hit RETURN to cancel request
 so having that be "text" or "binary" would still read well (although still
 locked to English).
 thoughts?
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1978#comment:2>
