[GRASS-dev] Projection problem: Indian_1954_UTM_Zone_48N, GRASS: Datum unknown
Yann Chemin ychemin at gmail.com
Fri Jun 14 00:03:37 PDT 2013
PROJCS["Indian_1954_UTM_Zone_48N",
    GEOGCS["GCS_Indian_1954",
        DATUM["Indian_1954",
            SPHEROID["Everest_Adjustment_1937",6377276.345,300.8017]],
        PRIMEM["Greenwich",0.0],
        UNIT["Degree",0.0174532925199433]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["False_Easting",500000.0],
    PARAMETER["False_Northing",0.0],
    PARAMETER["Central_Meridian",105.0],
    PARAMETER["Scale_Factor",0.9996],
    PARAMETER["Latitude_Of_Origin",0.0],
    UNIT["Meter",1.0]]
GRASS g.region -p after setting up a location from that shapefile
projection: 1 (UTM)
zone:       48
datum:      ** unknown (default: WGS84) **
ellipsoid:  everest
north:      2491572.35770828
south:      1346722.68241944
west:       -124919.66806446
east:       866700.463284
nsres:      57242.48376444
ewres:      49581.00656742
rows:       20
cols:       20
cells:      400
I can provide a shapefile to whoever is interested
