[GRASS-dev] [GRASS-SVN] r56717 - grass/trunk/demolocation/PERMANENT
Markus Neteler neteler at osgeo.org
Sat Jun 15 03:41:35 PDT 2013
On Sat, Jun 15, 2013 at 12:39 PM,  <svn_grass at osgeo.org> wrote:
> Author: hamish
> Date: 2013-06-15 03:39:21 -0700 (Sat, 15 Jun 2013)
> New Revision: 56717
> Modified:
>    grass/trunk/demolocation/PERMANENT/PROJ_INFO
> Log:
> "no defaults" not needed here. (see /usr/share/proj/proj_def.dat)
... then our mechanism to generate EPSG 4326 is suboptimal and
needs to be fixed. See
http://trac.osgeo.org/grass/changeset/56715
Markus
