[GRASS-dev] [GRASS GIS] #1131: Global LFS for wingrass
GRASS GIS trac at osgeo.org
Sat Jun 15 05:04:16 PDT 2013
 Reporter:  mmetz         |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  critical      |   Milestone:  7.0.0
Component:  LibGIS        |     Version:  svn-trunk
 Keywords:  LFS,wingrass  |    Platform:  MSWindows 7
      Cpu:  All           |
Comment(by glynn):
 Replying to [comment:20 mmetz]:
 > therefore I would not add new features unless they are required.
 Note that I wasn't suggesting changes to the configure checks per se.
 Rather, that if you want to test the checks, configure should be run with
 -ansi in CFLAGS so that tests don't pass simply by virtue of extensions
 having being enabled by default.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1131#comment:21>
