[GRASS-dev] spline interpolation over time series
Sören Gebbert soerengebbert at googlemail.com
Sun Jun 16 11:50:28 PDT 2013
Nikos is absolutely right, the ideal candidate for spline interpolation in
time for raster maps is r.series.interp. There is no other module that
performs temporal interpolation.
Best regards
Soeren
2013/6/16 Nikos Alexandris <nik at nikosalexandris.net>
> Margherita Di Leo wrote:
> > Hi all!
> > I need to analyse several MODIS in time, and calculate the temporal
> spline
> > interpolation (for each pixel), then pick the values (date and value) on
> > the spline function corresponding to percentiles 25, 50, 75, maximum,
> > minimum and average.
> > I know that with r.series I can get max, min and average, but I can't
> > currently apply a spline interpolation. I'd like to know if in the
> temporal
> > modules there's something to do that or I should hack the r.series in
> order
> > to add the spline interpolation.
> Maybe r.series.interp is a good/the proper candidate to receive such an
> addition?
> Nikos
> > I found this
> http://docs.scipy.org/doc/scipy/reference/tutorial/interpolate.html#spline-i
> > nterpolation that
> > I can probably use for the scope.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130616/3a4e89da/attachment.html>
