[GRASS-dev] [GRASS GIS] #86: d.rast.edit.tcl: doesn't start from wxPython without aspect map
GRASS GIS trac at osgeo.org
Mon Jun 17 01:17:44 PDT 2013
 Reporter:  hamish                 |       Owner:  grass-dev@…
     Type:  defect                 |      Status:  new
 Priority:  major                  |   Milestone:  6.4.3
Component:  wxGUI                  |     Version:  6.4.0 RCs
 Keywords:  d.rast.edit, wingrass  |    Platform:  MSWindows XP
      Cpu:  Unspecified            |
Comment(by hamish):
 requirement to have an aspect map for wingrass avoided in devbr6 with
 r56745.
 traceback and crash due to gcmd.py's `env = copy.deepcopy(self.env)`
 returning None side-stepped in devbr6 with r56751. I'm not sure if that
 actually makes a difference to the actually-needed search path since it's
 sys.path not os's $PATH, but it seems to work and doesn't make the
 PYTHONPATH list longer each time you run something, so even if it's
 useless it's not too polluting.
 I notice when the module is done (on linux) the wxGUI module wrapper never
 returns, you have to close it with the windows's upper-right "X" button
 since the close button remains shaded out. Also error messages (such as
 map already exists and no --o given) end up in the terminal not the wxGUI
 output window.
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/86#comment:5>
