[GRASS-dev] G7 compile error:
Johannes Radinger johannesradinger at gmail.com
Tue Jun 18 07:40:03 PDT 2013
I just tried to compile the recent G7 SVN but several error appeared:
GRASS GIS 7.0.svn 56779M compilation log
Started compilation: Tue Jun 18 16:23:06 CEST 2013
Errors in:
/usr/local/src/grass7_trunk/lib/ogsf
/usr/local/src/grass7_trunk/lib/nviz
/usr/local/src/grass7_trunk/misc/m.nviz.image
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Tue Jun 18 16:34:38 CEST 2013
make: *** [default] Error 1
radinger at grassgis:/usr/local/src/grass7_trunk$ cd
radinger at grassgis:/usr/local/src/grass7_trunk/lib/ogsf$ make
gcc  -g  -fPIC
-I/usr/local/src/grass7_trunk/dist.i686-pc-linux-gnu/include
-D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -I/usr/include/gdal
-I/usr/include  -DPACKAGE=\""grasslibs"\"     -I/usr/include/libavcodec
-I/usr/include/libavformat -I/usr/include/libswscale
-I/usr/local/src/grass7_trunk/dist.i686-pc-linux-gnu/include -o
OBJ.i686-pc-linux-gnu/gsd_img_mpeg.o -c gsd_img_mpeg.c
gsd_img_mpeg.c:33:25: fatal error: mathematics.h: No such file or directory
compilation terminated.
make: *** [OBJ.i686-pc-linux-gnu/gsd_img_mpeg.o] Error 1
radinger at grassgis:/usr/local/src/grass7_trunk/lib/ogsf$ cd
/usr/local/src/grass7_trunk/lib/nviz/
radinger at grassgis:/usr/local/src/grass7_trunk/lib/nviz$ make
gcc -shared -o /usr/local/src/grass7_trunk/dist.i686-pc-linux-gnu/lib/
libgrass_nviz.7.0.svn.so-L/usr/local/src/grass7_trunk/dist.i686-pc-linux-gnu/lib
-Wl,--export-dynamic  -L/usr/lib
-Wl,-rpath-link,/usr/local/src/grass7_trunk/dist.i686-pc-linux-gnu/lib
OBJ.i686-pc-linux-gnu/change_view.o OBJ.i686-pc-linux-gnu/cplanes_obj.o
OBJ.i686-pc-linux-gnu/draw.o OBJ.i686-pc-linux-gnu/exag.o
OBJ.i686-pc-linux-gnu/lights.o OBJ.i686-pc-linux-gnu/map_obj.o
OBJ.i686-pc-linux-gnu/nviz.o OBJ.i686-pc-linux-gnu/position.o
OBJ.i686-pc-linux-gnu/render.o  -lgrass_ogsf.7.0.svn -lgrass_gis.7.0.svn
-L/usr/include/GL  -lGL   -lSM -lICE -lX11  -lm
/usr/bin/ld: cannot find -lgrass_ogsf.7.0.svn
collect2: ld returned 1 exit status
make: *** [/usr/local/src/grass7_trunk/dist.i686-pc-linux-gnu/lib/
libgrass_nviz.7.0.svn.so] Error 1
radinger at grassgis:/usr/local/src/grass7_trunk/lib/nviz$ cd
/usr/local/src/grass7_trunk/misc/m.nviz.image/
radinger at grassgis:/usr/local/src/grass7_trunk/misc/m.nviz.image$ make
make: *** No rule to make target
`/usr/local/src/grass7_trunk/dist.i686-pc-linux-gnu/lib/
libgrass_ogsf.7.0.svn.so', needed by
`/usr/local/src/grass7_trunk/dist.i686-pc-linux-gnu/bin/m.nviz.image'.
Stop.
So how do I have to deal with that problems?
/Johannes
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130618/1d4f3ee5/attachment.html>
