[GRASS-dev] GSOC wk1 checkin
Hamish hamish_b at yahoo.com
Sun Jun 23 02:40:35 PDT 2013
Hi Tim, glad to see you're underway.
is it possible to post some data samples on your project's blog? (a description + figure would be great) It would help to get a better idea of what the import options would be for those three datasets. What form is the Natural Resources Conservation Service survey data in?
If you like/need I can poke around here for some more datasets.
> My work product next week is going to focus on the interpolation
> module. The abstract workflow for the module as whole is as follows
> Process for generation of r3 voxel grid from a population of xy
> located 1 dimensional horizon descriptions
>  1. Import of database horizon descriptions
>  2. Generation of line vector representing the path of the horizon
>  description in xyz
note that GRASS vector lines can not store per-vertex attribute data,
only per-line attribute data. Anything else must be stored as points;
see the v.in.gps module. one idea is to trick the vector engine into storing depth vs. value1 [vs. value2] in x,y[,z] structure. then translate out the results at the last step when you need real earth-coord x,y,z.
>  3. Segmentation of the line vector into n number xyz points
so binning by depth segment?
>  4. query of attribute values to points from attribute database
>  5. Generation of r3 region
>  6. Interpolation of point attribute values through geostatistical
>   and/or logical operators onto voxel grid locations
wrt to single x,y location well log, it seems to me like the r3.in.xyz
module already gives you most of that, bypassing the vector line stage
completely. binning 3D data into voxels using univariate statistics is precisely what it does.
are you looking to interpolate/aggregate vertically first, then
horizontally? would you interpolate at each depth band separately
then combine those together?
how well does that work with dipping angles? perhaps v.vol.rst could help too, to interpolate everything at once in a more 3D-influenced model?
> One point that Ben articulated was that the interpolation assignment
> needs to be capable of operating on integer data so that it can work
> on
that got cut off, but I guess you mean categorical value, so nearest
neighbour is needed, and not linear, cubic, or spline.
> Best wishes on this first day of summer.
Up to my knees in snow yesterday, but good mountain boots and funner than the rain and sleet that was falling down in the valley. :)
regards,
Hamish
