[GRASS-dev] [GRASS GIS] #2015: Missing file association dialog pops up all the time
GRASS GIS trac at osgeo.org
Tue Jun 25 20:03:44 PDT 2013
 Reporter:  wenzeslaus  |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  7.0.0
Component:  Python      |     Version:  svn-trunk
 Keywords:  wingrass    |    Platform:  MSWindows 7
      Cpu:  All         |
Comment(by hamish):
 A couple quoting fixes around GRASS_PYTHON in r56927-9, but that's all
 start-up, nothing to do with file associations AFAICT.
 Tested most recent nightly build of grass7 (r56911) with those fixes
 applied by hand on a fresh install of XP (so no parallel installs of other
 python versions), seems to be working for me.
 Displaying a raster map, starting the carto composer tool worked fine for
 me, although an error I did see was the mapswipe tool complaining when I
 clicked the help button about `'NoneType' object has no attribute 'Help'`.
 If I do `echo %PATHEXT%` at a regular C:\> prompt outside of grass7 I have
 no .PY on the list, from a grass7 command line session I do. Do you have
 the same?
 also try:
  C:\> ftype Python.File
 and
  C:\> ftype | grep -i python
 and
  C:\> assoc | grep -i py
 from within the GRASS session and look for anomalies. (maybe compare with
 outside a grass session, but grep might not work without extrabin in the
 %PATH%)
 see also
  - http://stackoverflow.com/questions/9037346/making-python-scripts-run-
 on-windows-without-specifying-py-extension
  - http://stackoverflow.com/questions/4727480/how-do-i-make-my-perl-
 scripts-act-like-normal-programs-on-windows
 hmm, Raster -> r.mask
   File "C:\Program Files\GRASS GIS
 7.0.svn\etc\gui\wxpython\lmgr\frame.py", line 737, in
 OnMenuCmd
 cmd = self.GetMenuCmd(event)
 7.0.svn\etc\gui\wxpython\lmgr\frame.py", line 722, in
 GetMenuCmd
 input = GUI().GetCommandInputMapParamKey(cmdlist[0])
 7.0.svn\etc\gui\wxpython\gui_core\forms.py", line 2310, in
 tree =
 etree.fromstring(gtask.get_interface_description(cmd))
 7.0.svn\etc\python\grass\script\task.py", line 461, in
 "\n\nDetails: %(det)s") % { 'cmd' : cmd, 'det' :
 decode(cmderr) }
 grass.script.core
 ScriptError
 Unable to fetch interface description for command 'r.mask'.
 Details: C:\Program Files\GRASS GIS
 7.0.svn\extrabin\python.exe: can't open file 'r.mask':
 [Errno 2] No such file or directory
 but now restarting GRASS and restarting it works fine, so I'm not sure,
 maybe that r.mask error was just a temporary glitch(?).
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/2015#comment:3>
