[GRASS-dev] compilation of grass on AIX 7.1
Markus Metz markus.metz.giswork at gmail.com
Fri Jun 28 11:29:01 PDT 2013
On Fri, Jun 28, 2013 at 7:13 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Jun 26, 2013 at 7:40 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> Now trying to get shared libraries enabled (almost there).
> Also enabled in SVN (thanks to Markus Metz).
> Interestingly, when *starting* GRASS 7, I get on that AIX machine:
> Cleaning up temporary files...
> Starting GRASS GIS...
> Could not load program g.gisenv:
> Could not load module
> /gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_gis.7.0.svn.so.
>         Dependent module /usr/lib/libiconv.a(libiconv.so.2) could not be loaded.
>         Member libiconv.so.2 is not found in archive
> Could not load module g.gisenv.
>         Dependent module
> Could not load module .
>         Dependent module
> Indeed, the libconv stuff is in /opt/freeware/ but searched in the common
> /usr/ directories. Existing:
> /usr/include/iconv.h
> /* @(#)09       1.20  src/bos/usr/include/iconv.h, libiconv, bos610
> 8/28/03 11:09:44 */
> /* IBM_PROLOG_END_TAG                                                     */
> but no corresponding libiconv.
> How to tell GRASS 7 in configure to pick up the  /opt/freeware/ include file and
> library?
In general, you can use some influential environment variables:
  CFLAGS      C compiler flags
  LDFLAGS     linker flags, e.g. -L<lib dir> if you have libraries in a
              nonstandard directory <lib dir>
  LIBS        libraries to pass to the linker, e.g. -l<library>
  CPPFLAGS    (Objective) C/C++ preprocessor flags, e.g. -I<include dir> if
              you have headers in a nonstandard directory <include dir>
If some components are in non-standard /opt/freeware/, you could try to set
LDFLAGS="-bsvr4 -R/opt/freeware/lib" CPPFLAGS="-I/opt/freeware/include"
Markus M
