[GRASS-dev] r.statistics in G7
Hamish hamish_b at yahoo.com
Sat Jun 29 18:20:08 PDT 2013
Helmut wrote:
>>> r.statistics2 is intended to be a partial replacement for r.statistics,
>>> with support for floating-point cover maps at the expense of not support
>>> quantiles. [1]
>>> r.statistics3 is intended to be a partial replacement for r.statistics,
>>> with support for floating-point cover maps. It provides quantile
>>> calculations, which are absent from r.statistics2. [2]
Glynn wrote:
>> r.statistics2 and r.statistics3 are intended to replace r.statistics.
>> But those two modules have almost nothing in common. r.statistics2
>> calculates statistics which are based upon accumulators (i.e. count,
>> sum of x^n, sum of (x-mean)^n), while r.statistics3 calculates
>> quantiles.
>> If you want a work-alike replacement for r.statistics, it would be
>> simpler to create a script which just runs r.statistics2 and/or
>> r.statistics3 to do the work.
>> In the event that you want both types of statistics, there could be
>> some efficiency gains to be had by merging the two, but only at the
>> cost of creating a module which is noticeably more complex than the
>> sum of its parts.
Madi:
> Thank you for the explanation! I perfectly agree that it's better to
> keep a couple of modules instead of a very complex one. But from the
> user's POV their names at the moment are not very informative. If you
> consider also r.stats... how could the user guess what's the purpose of
> them all at the first glance? Perhaps names like r.stats.*, where * is
> the particular function that they perform, would be a bit easier to
> understand (?)
perhaps -> r.stats.cover and r.stats.quantile?
we should also add r.stats (and perhaps r.univar) into this discussion.
r.stats -> r.stats.summary ?
Hamish
