[GRASS-dev] [GRASS GIS] #2018: Provide a way to edit the PERMANENT/MYNAME file
GRASS GIS trac at osgeo.org
Sun Jun 30 07:09:10 PDT 2013
 Reporter:  nikosa                         |       Owner:  grass-dev@…
     Type:  enhancement                    |      Status:  new
 Priority:  normal                         |   Milestone:  6.4.4
Component:  Default                        |     Version:  unspecified
 Keywords:  location, description, ps.map  |    Platform:  Unspecified
      Cpu:  Unspecified                    |
 Besides _editing_ the PERMANENT/MYNAME file manually (later, not while
 creating a Location), is there a "proper" way to do so?  It is used for
 example by the "header" instruction in ps.map.
 I can't trace a single reference about it in any of the user-manuals
 except for in ps.map's section about the header instruction
 <http://grass.osgeo.org/grass64/manuals/ps.map.html#header>:
 %L - Location's text description
 And, of course, in the Programmer's manual, i.e. in
 <http://grass.osgeo.org/programming7/myname_8c.html>.
 Maybe add an option to "g.proj" or an(other) environment variable
 "LOCATION_DESCRIPTION" to be set with "g.gisenv"?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2018>
