[GRASS-dev] [GRASS GIS] #1901: v.mkgrid near ", ": syntax error, no batch insert
GRASS GIS trac at osgeo.org
Fri Mar 1 02:18:21 PST 2013
#1901: v.mkgrid near ",": syntax error, no batch insert
 Reporter:  pertusus     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Vector       |     Version:  svn-trunk
 Keywords:               |    Platform:  Linux
      Cpu:  Unspecified  |
 A v.mkgrid leads to:
 v.mkgrid map=grid_map_v grid=$rows,$cols
 DBMI-SQLite driver error:
 Error in sqlite3_prepare():
 ERREUR :Unable to insert new record: insert into grid_map_v values ( 1, 1,
         1 ), ( 2, 1, 2 ), ( 3, 1, 3 ), ( 4, 1, 4 ), ( 5, 1, 5 ), ( 6, 1, 6
         ), ( 7, 1, 7 ), ( 8, 1, 8 ), ( 9, 1, 9 ), ( 10, 1, 10 ), ( 11, 1,
         11 ), ( 12, 1, 12 ), ( 13, 1, 13 ), ( 14, 1, 14 ), ( 15, 1, 15 ),
         16, 1, 16 ), ( 17, 1, 17 ), ( 18, 1, 18 ), ( 19, 1, 19 ), ( 20, 1,
         20 )
 Trying manually:
 db.execute sql=" insert into grid_map_v values ( 3, 1, 3 ), ( 4, 1, 4 )"
 And trying in sqlite directly:
 sqlite> create table grid_map_v ( cat INTEGER, row INTEGER, col INTEGER );
 sqlite> insert into grid_map_v values ( 1, 1, 1), ( 2, 1, 2 );
 Error: near ",": syntax error
 sqlite> insert into grid_map_v values ( 1, 1, 1);
 The batch insertion is shown in http://www.sqlite.org/lang_insert.html,
 however I am not sure that it is standard sql.  I don't know where to find
 the standard, but on http://troels.arvin.dk/db/rdbms/#insert-multiple it
 is described as optional.
 The commit that introduced that issue is the last commit
 r53891 | marisn | 2012-11-18 13:40:34 +0100 (dim. 18 nov. 2012) | 1 ligne
 Make some errors more fatal; Write attribute data in batches per 20 to
 speed up module 16x times
 I will set BATCH_SIZE 1 for now but I am not sure it is the correct fix.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1901>
