[GRASS-dev] is r.stream.stats available for G6 on linux?
Markus Neteler neteler at osgeo.org
Wed Mar 13 04:22:02 PDT 2013
On Wed, Mar 13, 2013 at 12:14 PM, Margherita Di Leo
<dileomargherita at gmail.com> wrote:
> Hi devs,
> I was checking the status of the availability of addons [1] and I am
> surprised to find out that some addons compile on windows but not on linux
> (GRASS 6), I'm talking about some r.stream.*, particularly r.stream.stats,
> which is a dependency of r.basin. Checking the log [2] it seems a problem in
> the variable declaration,
Yes, it was not done in a way satisfying current gcc compiler versions:
/home/neteler/grass-addons/grass6/raster/r.stream.stats/print_stats.c:8:
multiple definition of `fifo_outlet'
OBJ.x86_64-unknown-linux-gnu/io.o:/home/neteler/grass-addons/grass6/raster/r.stream.stats/io.c:5:
first defined here
OBJ.x86_64-unknown-linux-gnu/print_stats.o: In function `print_stats':
multiple definition of `tail'
first defined here
/home/neteler/grass-addons/grass6/raster/r.stream.stats/print_stats.c:12:
multiple definition of `head'
first defined here
The author(s) or a volunteer needs to fix that. My last attempts were
suboptimal,
not really my domain :-)
Markus
