[GRASS-dev] compiling grass 7.0 fails
Paulo van Breugel p.vanbreugel at gmail.com
Wed Mar 20 04:55:06 PDT 2013
Thanks!
On Wed, Mar 20, 2013 at 9:23 AM, Sören Gebbert <soerengebbert at googlemail.com
> wrote:
> Hi,
> sorry, that was my fault. I have committed the correct 3D raster
> library header files. Revision 55464 should work now.
> Best regards
> Soeren
> 2013/3/20 Paulo van Breugel <p.vanbreugel at gmail.com>:
> > Hi, I am trying to compile grass 7.0 (revision 55463). I am getting a
> lot of
> > errors, with the first folder with error the 'lib/raster3d'
> > Going there and running make gives me the following:
> > gcc  -g -O2  -fPIC
> -I/home/paulo/Software/spatial/grass7_trunk/dist.x86_64-unknown-linux-gnu/include
> > -D_FILE_OFFSET_BITS=64  -DPACKAGE=\""grasslibs"\"
> > -o OBJ.x86_64-unknown-linux-gnu/changeprecision.o -c changeprecision.c
> > changeprecision.c: In function ‘Rast3d_change_precision’:
> > changeprecision.c:35:5: error: too few arguments to function
> > ‘Rast3d_get_compression_mode’
> > In file included from
> /home/paulo/Software/spatial/grass7_trunk/dist.x86_64-unknown-linux-gnu/include/grass/raster3d.h:261:0,
> >                  from changeprecision.c:5:
> /home/paulo/Software/spatial/grass7_trunk/dist.x86_64-unknown-linux-gnu/include/grass/defs/raster3d.h:82:6:
> > note: declared here
> > changeprecision.c:36:5: error: too few arguments to function
> > ‘Rast3d_set_compression_mode’
> /home/paulo/Software/spatial/grass7_trunk/dist.x86_64-unknown-linux-gnu/include/grass/defs/raster3d.h:81:6:
> > note: declared here
> > changeprecision.c:50:5: error: too few arguments to function
> > note: declared here
> > make: *** [OBJ.x86_64-unknown-linux-gnu/changeprecision.o] Error 1
> > Any ideas?
> > Paulo
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130320/abe5fe07/attachment-0001.html>
