[GRASS-dev] Using "trac" is difficult
Nikos Alexandris nik at nikosalexandris.net
Wed Mar 20 10:33:31 PDT 2013
Nikos Alexandris:
> >> > I feel that trac makes it difficult (for me) to write and structure the
> >> > text for a ticket.  I am forced to manually enter [[BR]] to break
> >> > lines!
Markus Neteler:
> Please don't... it becomes really unreadable.
Nikos A:
> > Indeed, but I still  don't find it very convenient.  I should put a new
> > line for all of the following then:
> > [1]  http://www.cs.umd.edu/~mount/Projects/ISODATA/
> > [2] http://help...
> Remember that a bugtracker is not a typesetting system. Simple formatting
> is preferred as well as using the trac Wiki features. A numbered list
> could be easily generated, IMHO no need to have the (overly) fancy
> brackets. The shorter, the better :)
Sure, but why I see for example the supposed list build with a *  in front of
each line not being a list?  (shrug)
e.g.  http://picpaste.com/in_trac_asterisks_not_building_a_list-NHQQRYVm.png
Shouldn't the list be built automagically?
Best, N
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130320/830381e2/attachment.pgp>
