[GRASS-dev] [GRASS GIS] #1866: broken db driver communication in winGRASS 7
GRASS GIS trac at osgeo.org
Wed Mar 20 13:12:54 PDT 2013
 Reporter:  martinl           |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  blocker           |   Milestone:  7.0.0
Component:  Database          |     Version:  unspecified
 Keywords:  sqlite, wingrass  |    Platform:  MSWindows 2K
      Cpu:  Unspecified       |
Comment(by hellik):
 Replying to [comment:29 mmetz]:
 > Replying to [comment:28 glynn]:
 > > Replying to [comment:27 mmetz]:
 > > > Should the fix be backported to GRASS 6?
 > > Yes.
 > Done in r55432,3.
 maybe related?
 Copy vector <firestations at PERMANENT> to current mapset as <myhell>
 WARNING: Unable to start driver <dbf>
 WARNING: Unable to copy table <myhell>
 WARNING: Cannot copy <firestations at PERMANENT> to current mapset as
 <myhell>
 v.db.addcol map=testvect at user1 columns=ti integer
 ERROR: Unable to start driver <dbf>
 ERROR: Cannot continue (problem adding column).
 tested with
 System Info
 GRASS version: 6.4.3svn
 GRASS SVN Revision: 55442
 GIS Library Revision: 50937 (2012-02-25)
 GDAL/OGR: 1.9.2
 PROJ4: Rel. 4.8.0, 6 March 2012
 Python: 2.7.2
 wxPython: 2.8.12.1
 Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
 Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1866#comment:30>
