[GRASS-dev] Using "trac" is difficult
Vaclav Petras wenzeslaus at gmail.com
Thu May 2 07:14:33 PDT 2013
Just a small update. The situation will be hopefully improved some
day. Trac 0.12 supports live preview. From the change log [1]:
 * Usability improvements for the Wiki, with a nice side-by-side edit
mode with automatic preview
 * Usability improvements for the Ticket module, with automatic
preview of comments while you type and possibility to edit or remove
them later
I don't see the preview in the demo for 0.12 (maybe it is turned off
by default) but 1.0 (last stable is 1.0.1.) has it [2].
The different syntax problem will be still there but it will be much
more convenient to check your syntax.
We are using Trac 0.11.7.
[1] http://trac.edgewall.org/wiki/ChangeLog#a0.12Babel
[2] http://trac.edgewall.org/demo-1.0/newticket
